× Urgent: Activate Two-Step Verification
Arlo requires all users to activate two-step verification by Nov 30th, 2020 to continue to access your recordings, devices, and account.
Please enable this feature now. Learn More.
Message says looking for your Arlo camera - Essential Spotlight
  • 10 Replies
  • 307 Views
  • 6 In Conversation
Highlighted
I'm having this issue with the essential spotlight camera. It does not detect my camera.. I've tried all of this.. any look from anyone else??
Model: VMC2030 | Arlo Essential Spotlight Camera
Highlighted
Hi @Frbarnes1975
Have you tried on the Arlo mobile app & web portal?
Highlighted
Yes I've tried both.. and it just spins then says it can't be found.
Highlighted
Are you trying to connect to a Base Station/SmartHub or directly to your router?
Highlighted
Directly to router
Highlighted
I had the same issue and after trying many things including calling CS, I found that my wifi password was wrong. I entered the correct one and it worked! Just bought these today and setup takes a while especially because instructions aren't too detail. Hope it helps.
Highlighted
Password is correct.. it just can't locate the camera.
Highlighted
@Autumn6230 Thank you for that info,
@Frbarnes1975 Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Highlighted
Any luck on this? I'm going to send it back tomorrow if not. I tried everything. Only thing I can think of is SSID is wrong somehow.. Maybe not include dash etc. I've tried app, mobile web, reset, complete charge. It scans fine on 2g.. But still nothing. Blinks blue then red after timing out
Highlighted
Seddy21086,
At what point are you experiencing the issue? Could you provide a screenshot of the error you're seeing?
Highlighted
Same here, returned previous which worked for 2 months, purchased new one, app wont find..Replaced router with provider, password correct for 2.4ghz, now app says limit reached when I only have this replacement camera, I bypass the pop up and still not discovered. App settings say no camera
Model: VMC2020 | Arlo Essential
  • 10 Replies
  • 308 Views
  • 6 In Conversation
