- English
- Cameras
- Message says looking for your Arlo camera - Essent...
Message says looking for your Arlo camera - Essential Spotlight
I'm having this issue with the essential spotlight camera. It does not detect my camera.. I've tried all of this.. any look from anyone else??
Are you trying to connect to a Base Station/SmartHub or directly to your router?
I had the same issue and after trying many things including calling CS, I found that my wifi password was wrong. I entered the correct one and it worked! Just bought these today and setup takes a while especially because instructions aren't too detail. Hope it helps.
@Autumn6230 Thank you for that info,
@Frbarnes1975 Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Seddy21086,
At what point are you experiencing the issue? Could you provide a screenshot of the error you're seeing?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
