- English
- Cameras
- How to connect a VMA5600 solar panel to a VMC2030 ...
As per the pictures, the VMA5600 solar panel has a magnet and three pins in a triangle while the base of the camera has a USa
USB port. So how does the solar cable connect to the camera?
The two devices are not compatible. A different model solar panel is required
Hi ArloPro3,
You will need to use the Arlo Essential Solar Panel (VMA3600) to use with the Arlo Essential Wire-Free Cameras.
The amount of energy that the solar panel can produce is affected by how much sunlight the Connect the other end of the cable to your Arlo camera.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
