- English
- Arlo Forum Discussions
- Arlo Essential Camera Series
- Re: How to connect a VMA5600 solar panel to a VMC2...
Re: How to connect a VMA5600 solar panel to a VMC2030 camera
- Email to a Friend
As per the pictures, the VMA5600 solar panel has a magnet and three pins in a triangle while the base of the camera has a USa
USB port. So how does the solar cable connect to the camera?
- Email to a Friend
The two devices are not compatible. A different model solar panel is required
All Replies
- Email to a Friend
- Email to a Friend
Hi ArloPro3,
You will need to use the Arlo Essential Solar Panel (VMA3600) to use with the Arlo Essential Wire-Free Cameras.
- Email to a Friend
The amount of energy that the solar panel can produce is affected by how much sunlight the Connect the other end of the cable to your Arlo camera.
Arlo Essential Spotlight
