- English
- Cameras
- Essential spotlight camera - image tinted red
Camera image is tinted red ?.?
You have a first! Since you can't pull the battery to reset it, try removing the camera from Settings, My Devices as well as using the reset procedure by holding the button for >10 seconds. Reconnect it to see if that helped. If not, use the Contact Support link at the bottom here.
Fuj,
Please provide a video clip/screenshot of what you are experiencing. Does this happen on recorded content as well as live streaming?
Sadly no cure found.
All combinations of app/camera/night vision removal/re-installation tried but no success.
Camera has been exchanged by Amazon.
Oldschool1503,
Try removing the camera, factory reset, and re-sync. Do you still experience the same issue?
Factory reset instructions can be found on page 67 here: https://www.arlo.com/en-us/images/documents/arloessential/Arlo_Essential_Device_UM_US.pdf
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
