Essential Battery Life
- Email to a Friend
HI, I upgraded from the Arlo Pro (Had combo or 1st and 2nd Gen) to a 2 pack Essentials. With the Essentials, one Camera is not holding charge. I have swapped the camera locations, disconnected and reconnected to the network. Both Cameras have a strong network connection as the router is just inside the window so only transmitting through glass. The one holding charge is further away and does 10 videos a day where the one not hold charge does 1-2. I have both hooked up to a solar panel which makes no differance with the faulty unit. (i have tried with and without the solar panels on both) Spotlight has been deactived. I have logged a case asking for a replacement of the faulty unit #42213861 but wondering if anyone else has any ideas. Based on all tests I have completed it appears the one unit if faulty requiring a wall power charge daily.
- Email to a Friend
Continue to use support or swap at the store.
- Email to a Friend
Hi,
So i have the Arlo Essential Spotlight camera and just recently one of the cameras will not hold charge. I charged it 3 times in last few days. I had for one day 8 motions and it drained the battery to 14 percent and has never done that. Did you find a solution yet? I have reset mine and charged it and nothing helps. I only had the camera barely going on 4 months.
- Email to a Friend
CM8,
How far is the camera from your base station/router? What does the signal strength icon show?
- Email to a Friend
No Solution, I have requested RMA
- Email to a Friend
Both have 'Strong' Signal either with my router or my base station
