- English
- Cameras
- Discovery Failed - Your device could not be discov...
Discovery Failed - Your device could not be discovered.
I'm experiencing the title issue, I tried to setup the cam via mobile app and computer, but both failed.
The blue light of the cam either flash about 30 seconds and then off or flashing rapidly with amber light after 2 mins...
I tried the factory reset and then pair up again, but still no luck.
Anyone have same experience? How can I fix it?
alexishu,
Try charging the camera first and then attempt to sync again once it is fully charged. Do you still experience the same behavior?
Tried to charge it for a day and then sync again, but still the same.. 😞
alexishu,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Hold down button until light flashes Orange, Then try again.
Same problem here! im in contact with TS and so far no solution! bought 3 cameras and all 3 have the same problem. Did you got any solution?
FAECU,
Are you trying to sync to a base station/smarthub or directly to your WiFi network?
FAECU,
Be sure the cameras are fully charged, try factory resetting and then attempt to sync again.
To factory reset your camera, take a look here: How do I factory reset my Arlo wire-free camera?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
