Battery charging the Arlo Essential
Does it take a long time to charge the battery, the battery % charge indicator is very slowly increasing over about 13 hours from very low to about 15% Is this Normal? TU
dennis007,
It should only take up to a few hours to fully charge the camera. Are you using the charging cable that was included with your Arlo Essential kit?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
