- English
- Arlo Forum Discussions
- Arlo Essential Camera Series
- Re: Arlo Pro 3 Spotlight Randomly Turning On for 3...
Re: Arlo Pro 3 Spotlight Randomly Turning On for 3 Seconds
- Email to a Friend
One of my Arlo Pro 3 Camera’s light is Randomly Turning On for 3 Seconds.
I’ve tried resetting it. Turning the spotlight on and off. Nothing seems to work.
Model: VMC4040P | Arlo Pro 3 Wire-Free Camera
- Email to a Friend
Define "reset" - pull the battery or used the reset process?
- Email to a Friend
Charrison15,
Are recordings being made when the light turns on or is it just the light turning on? Is the camera Armed?
- Email to a Friend
All of the above.
- Email to a Friend
JamesC - The camera with the light issue is not recording, but is on.
There is another camera in the room (Arlo Baby Camera) that is capturing the light turning on though.
- Email to a Friend
Charrison15,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Arlo Essential Spotlight
