- English
- Cameras
- Re: Arlo Pro 3 Spotlight Randomly Turning On for 3...
One of my Arlo Pro 3 Camera’s light is Randomly Turning On for 3 Seconds.
I’ve tried resetting it. Turning the spotlight on and off. Nothing seems to work.
5 REPLIES 5
Define "reset" - pull the battery or used the reset process?
Charrison15,
Are recordings being made when the light turns on or is it just the light turning on? Is the camera Armed?
All of the above.
JamesC - The camera with the light issue is not recording, but is on.
There is another camera in the room (Arlo Baby Camera) that is capturing the light turning on though.
Charrison15,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
