- English
- Cameras
- Arlo Essential taking so long to connect to live f...
Arlo Essential taking so long to connect to live feed
I recently bought an Arlo Essential Camera. When I first connected it, it says full signal strength. It still shows full signal strength. I am able to use my siren. It catches motion, but it takes forever for connect to live. Sometimes it even says “failed to connect. Try again.”??
Trev08,
This is generally a symptom of a connectivity issue between the camera and the base station/SmartHub. Try moving your base station/SmartHub as far away from your router as possible. Elevating it may also help improve signal strength and reduce potential WiFi interference.
Test again to see if you experience the same behavior.
jamesC
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
