- English
- Cameras
- Arlo Essential camera disconnects after a minute.
Hi, my camera disconnects after a few minutes and will not get back online. I have connected it to my 2.4 ghz router. (Have disabled 5 ghz). Turned of all other units using wi-fi and 2,4 ghz except my phone that is of course needed to connect. (Only get a week wi-fi signal from my neighbour). Sometimes camera is connected for a minute, other times it stays connected for two mins. Could it be hat Arlo simply isn't compatible with my specific router? I have tried to vary the distance for the camera from 3 to 40 feet with no luck or change in behaviour. At first I thought it was to cold outside. -17c/1.4f but specs promises capabillity down to -20c/-4f, but trying indoors is just the same.
Think it might not be faulty, but some serious bug it has obviously. Thank god I ordered it online. In my country we have a law that says that anything you buy online can be returned no-questions-asked for a full refund within 14 days. Too bad. It was definitely something like this I needed so I have to go shopping for other brands.
You can try a reset using the procedure in https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera as well as removing the camera from Settings, My Devices. If that doesn't help, swapping at the store could provide the solution.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
