× Urgent: Activate Two-Step Verification
Arlo requires all users to activate two-step verification by Oct 31st, 2020 to continue to access your recordings, devices, and account.
Please enable this feature now. Learn More.
Arlo Essential Battery Life
  • 7 Replies
  • 439 Views
  • 6 In Conversation
Highlighted
Recently purchased two cams. Both batteries are currently only lasting 1-2 DAYS, even on battery-saver mode with full wifi signal strength. Video does not record more than 5 min a day. What is going wrong?
Model: VMC2030 | Arlo Essential Spotlight Camera
Highlighted
Bring a camera close to the base/router to see if makes a difference.
Highlighted
you could also reset the cameras by using remove device and re-installing
test again
Highlighted
DearLiza,
This could be due to poor signal strength or interference. As suggested above, try bringing the camera close to your base/router  temporarily and test again to see if you experience the same behavior.
Highlighted
Thanks. I did bring both cameras closer to my Wifi router (no base stations with the Essential). It seemed to improve battery life fairly significantly, but I'm still seeing frequent drops in battery percentage from day to day. I'm thinking now it is due to my unstable Wifi and the cameras having to reconnect a few times throughout the day. Will keep everyone updated! Thanks!
Highlighted
How many total minutes per day of live viewing and recording are going on? If frequently >5 minutes per day that could explain the battery drop.
Highlighted
What planet do you live on ?
Highlighted
Mentor
Mentor
I think you have to be on the earth to post.
  • 7 Replies
  • 440 Views
  • 6 In Conversation
