  • 4 Replies
  • 4038 Views
deville1975
Connection issues with my Arlo baby camera as all of a sudden the amber lite stayed solid.
When I disconnected from the power and reconnected, the light comes on immediately and remain solid Amber also.
I have tried putting a paperclip in the rever hole and holding for 10 (plus) seconds several times as suggested to make it factory default again so that I can ado it as a new camera but the light once again stay solid Amber even with the clip inserted.
make sure you turn off the battery ( under feet ) and then while plugged into power do a reset
deville1975
Thanks, tried that. No luck
jutitoo
Having similar issues as well. Stuck on getting the device added back to app. I'd get a chime and a solid blue light, but camera can't be found by app
deville1975
on the off chance that Support are looking at this, your update case links do not work therefore I am unable to reply to you. Case number 41570025
  • 4 Replies
  • 4039 Views
