Problems with Android App
  • 1 Reply
  • 1451 Views
Bcapewell92
Full screen option is mostly never visible. Sometimes it appears, otherwise it's just not the in the corner where its supposed to be. Tried stopping, restarting, reinstalling app, still an issue. Has been like this for months.
'library' and 'mode' buttons do not work, can't access any recordings. Very annoying.
Timeline does not show where audio movement was (green and blue bars). I pay extra for this service. Used to work, does not anymore.
Tried everything to fix this myself. Reinstalled etc.
Using pixel 3 on Android 10 latest version.
Very poor app and very poor dev/qa standards.
ShayneS
Hi @Bcapewell92
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 1 Reply
  • 1451 Views
