Live Feed Down
  • 10 Replies
  • 25123 Views
  • 6 In Conversation
Acrorae
As of today, 9/22/24, the live feed is down. There's no update being requested for the app either. The app opens and shows the live view but then after 10 - 20 seconds it shuts off.
10 REPLIES 10
TwinCitiesJHawk
I can’t even get it to show for a few seconds. Must be a global server issue at arlo
There were some similar symptoms being reported that should now be resolved. For more information see here: status.arlo.com
Hitxfunsize
I can’t get my baby Arlo to connect back to the app. I’ve turned off and on, even factory reset….still can’t get the camera to connect to app. Are you still having issues?
Jayp01
I am still down and can’t get it to reconnect after several reset, uninstall, etc. for both the app and the Arlo baby.
If you've removed the baby camera from the app, you will need to make sure a factory reset completes successfully before you will be able to add it back to the app.
Follow the instructions here: https://kb.arlo.com/1282685/How-do-I-reset-Arlo-Baby-to-factory-default-settings
If you're having trouble adding the camera back to your account after the factory reset, this could mean the reset did not complete successfully, be sure to follow the instructions closely in the reset article.
Hitxfunsize
I waited for the camera to factory reset and still no luck in getting my baby Arlo to connect to the app.
Hitxfunsize,
If you're still experiencing an issue I recommend reaching out to the support team using the Arlo Secure app under Settings > Support. From there you can open a ticket to with a support agent to further investigate the issue.
Hitxfunsize
I went to support as stated in the reply, since my baby can doesn’t show it won’t allow me to open a ticket.
101dB
Tried to add Arlo baby since yesterday but failed. Try again today and it's work now. Factory reset.... Normal procedures.
Hitxfunsize,
I see you were able to get a support ticket created. Please let me know if you still need further assistance after working with the support team.
  • 10 Replies
  • 25124 Views
  • 6 In Conversation
