Help my baby cam doesn’t work
  • 2 Replies
  • 1542 Views
Arlodoesntwork1
My Arlo Baby is stuck on a solid Amber Light. I've tried doing all of the advice I've seen on the posts: turn off battery for 30 seconds, turn back on and replug in, hold reset button for 10 seconds, but it's not working.
If you do a search, you'll see a few others with this problem....
Many of the Baby cams when they fail do so this way and there is not much to do if you tried all the normal fixes.
Once again just in case;
Turn off battery under feet
Power down for a few mins
Power back up
do a full reset ( hold reset till the led flashes ( about 10 secs ))
Turn on and attempt to reinstall as if new.
if ok, turn battery on
Arlodoesntwork1
Thanks, yeah I’ve tried everything.
and yeah I see many many people with the same issue and Arlo doing nothing about it. Arlo obviously doesn’t care about thier customers at all anymore. Won’t be buying from them again after seeing all these reports online. What a crappy company.
  • 2 Replies
  • 1543 Views
