Camera not booting
  • 8 Replies
  • 5635 Views
Retired_Member
Not applicable
Hi, my camera appears to be frozen/unable to boot. It is displaying a constant orange light. A few days ago I turned the integrated light on and then it restarted and hasn’t been able to boot since. I’ve tried resetting by pressing reset for 10 seconds. Nothing. I’ve drained the battery. Nothing. Is it now landfill….
8 REPLIES 8
DannyBearAgain
Retired_Member
Not applicable
That's not relevant to my camera. It's an Arlo Baby. It's an indoor model and connects to WiFi only.
DannyBearAgain
Good point, sorry my bad.
BrookeN
Were you able to get the camera to unfreeze?
Retired_Member
Not applicable
No. And it's impossible to speak to someone at Arlo. I just get sent to a static page on how to reset the device.
BrookeN
With the device now being out of warranty there is no further steps that can be given since the device will no longer turn on.
Retired_Member
Not applicable
So it is now landfill…
Although I would argue it doesn’t fit within UK consumer statutory legal rights in that the camera must be satisfactory as described, fit for purpose, and last a reasonable length of time.
And the last one is crucial. Items must last a reasonable length of time, provided that you have behaved as you should with them.
I would appreciate if there is someone at Arlo to discuss this
BrookeN
I created a support ticket for you to discuss the concerns you posted above. They will reach out to you as soon as possible.
  • 8 Replies
  • 5636 Views
