Babycam audio to homekit
  • 2 Replies
  • 329 Views
Kriek
Hi,
A while back I bought the arlo babycam, I set it up and now that the baby is born we started using the device. One problem I found is that for now I cannot add audio to homekit. Is this a feature that will be supported in the near future?
My wife and I are both using homekit. I have the arlo app installed and can receive the audio detected notifications, but my wife does not receive homekit audio notifications, only motion.
It would be preferable that also audio is available in homekit. I do not want my wife needing to set up the arlo app only for audio notifications.
We have a monitor that measures the baby’s breathing as a so called cot death prevention measure. This monitor makes an audible sound and so in this case the audio notification is important to receive.
Awaiting your reply, Thanks in advance
Regards, Geert.
Model: ABC1000 | Arlo Baby
Briguy
I am am have the same problem. I will be following this topic. Thanks for posting
ShayneS
Please contact the Support Team to further investigate this. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 2 Replies
  • 330 Views
