Baby Arlo Not Connecting
The baby arlos keep flashing yellow. It recognizes the QR code and chimes when we try and connect it to our 2.5G wifi connection but then makes an unable-to-connect Atari noise and goes back to flashing yellow again. We have no other problem with any other device, including our other Arlo cameras. Please help!
Do you have any new special characters in your networks name SSID? You can find more information here: Can special characters in a network name cause problems
Can you PM with the email these baby cameras are associated with?
Is your baby camera uninstalled?
Is the camera disconnecting from the internet or shutting off in general/rebooting?
Can you try a factory reset one more time per this article: How do I reset Arlo Baby to factory default settings?
Can you PM me with your baby camera serial number, the one having the issue.
I have opened a case for you. Customer Support will be reaching out to you as soon as possible. I have provided the case number for your reference: 42922708
This situation describes me exactly as well. I have factory reset many times. My network works absolutely fine and is very high end. This camera is junk, it worked fine for a while but now it won't connect at all. I don't get the chime. It's just a flashing amber light until I press the sync button, it flashes blue but it won't get past that stage. It sounds like there is a problem with these cameras
I escalated your case and the escalations team will be contacting you by phone/email. Your escalations number is here: 42948081
I have notified the support team, I will look in to this ASAP. I will provide an update as soon as i hear more.
Hi @Kw2022,
Do you mind providing a screenshot of the error message?
Yes, see photos below. The error message displayed when I try to set up by clicking on the Arlo device discovered under "Found Cameras" is "an unexpected error occurred". The error message displayed when I try to set up the device using the QR code method is " No Arlo Devices Found - make sure your device is powered on correctly and you're connected to the network." As an aside, this happens even after doing a factory reset and after power cycling. The SSID is correct and case sensitive. The wifi network is working for other devices. The power cable is plugged into a functioning outlet at the battery switch is set to green. Thanks. error message from clicking on Found Camera
error message from QR code setup
Arlo Baby
