I thought I read somewhere that Arlo Baby had functionality to determine cry and intensity of said cry vs all other noise? When looking at audio settings, it's the same all other Arlo, just a 1-5 sensitivity rating. Am I missing something?
AFAIK, the sensitivity is the only setting, not the nature of the noise.
adambean,
Arlo Baby can notify you differently when the sound it detects is a cry vs a different sound. I believe this is the feature you are referring to.
"Baby Crying Alert - Not only can Arlo Baby alert you when a sound is detected, it will also tell you specifically if it is the sound of your baby crying."
Yeah, it does seem to work, but only if it's a very loud and intense cry ... then it says it was a cry vs. noise. Odd that it has this logic, but you can't have triggers/decisions based on what was detected. Seems like something that would be benficial.
Arlo Baby
