Arlo baby not charging problem
Hi, Arlo baby has stoped charging. It charges for a couple of seconds then stops.
Yes - i am using the original charger, i have tried with usb cable and it works.
It seems that the charger wont stay in the camera, the conection point seems wobbly and the charger is not firmly in place
Assume you mean the cable doesn't stay plugged into the baby.... the Baby socket is wobbly.
If so, you may have to contact Arlo support for possible warranty .... may be the usb socket has broken free from board.
Arlo Baby
