Arlo Baby temperature reading
Anyone having problems with the Arlo Baby temperature reading? My camera is showing 28 degrees, and the unit is warm in itself, I have a normal room thermostat which is saying 23.5 degrees. Does the heat of its own electrics workings affect the temp reading?
Pgsullivan,
Not to my knowledge. Have you tried rebooting the camera? Is the temperature more accurate after a reboot?
Yep
I have Ecobee sensors in the rooms with Arlo Babies. The Arlo tends to run 1-2 degrees F higher than the Ecobee sensors.
Arlo Baby
