Arlo Baby showing wrong temp. How to fix?
My app will show the completely wrong temperature. It will say it is extremely hot in my sons room and when I go to check it can be just fine or even too cool. Is there a fix or has anyone else experienced this?
Hi Samantharae,
Try re-calibrating your Arlo Baby's sensor to see if that helps. You can read here to learn how: How do I recalibrate Arlo Baby’s temperature, humidity, and air quality sensors?
Arlo Baby
