I bought an Arlo Baby 5 weeks ago,just it is works for 3 weeks only and from 2 weeks I have gone through the setup process on the app with no luck... The camera will chime once it reads the QR code, after that it will not discover the device. I have gone through the setup many times with no luck, I have also tried reseting the camera as suggested..
Hey
Did you find a solution for that? I'm facing the same problem.
Yes ... You have to press the reset button until the light come amber may you have to press for 20 seconds... then continue the setup....
Any luck? I have having the same problem. I want to just pack it back up and ship it back. This is very frustrating for parents.
Arlo Baby
