Arlo Baby cannot discover device
  • 4 Replies
  • 3227 Views
DUBAU_GHOST
I bought an Arlo Baby 5 weeks ago,just it is works for 3 weeks only and from 2 weeks I have gone through the setup process on the app with no luck... The camera will chime once it reads the QR code, after that it will not discover the device. I have gone through the setup many times with no luck, I have also tried reseting the camera as suggested..
Moe2019
Hey
Did you find a solution for that? I'm facing the same problem.
DUBAU_GHOST
Yes ... You have to press the reset button until the light come amber may you have to press for 20 seconds... then continue the setup....
PBJr
Any luck? I have having the same problem. I want to just pack it back up and ship it back. This is very frustrating for parents.
JessicaP
Hi @PBJr,
Have you tried what DUBAU_GHOST mentioned?
  • 4 Replies
  • 3228 Views
