How long is the Arlo Baby cord length? I want to make sure that I will be able to mount it pretty high up, and still reach an outlet.
Can't say since it's not out yet. If it uses the same or similar USB charger as the Pro and Q, you can always buy a longer QUALITY cable (quality is important since cheap ones use small wires, leading to voltage drop and issues).
No spec, as not release yet, As a guess, I would venture to say thats it's about the same as the Q cams / Pro cam cord ( btw, uses the same battery as Pro )... about 8 ft... so it may use the same cord / adapter as the Pro
But you can use a usb extension from the adater if need be
mross12,
Arlo Baby cable length is just under 10 feet.
Arlo Baby
