My Arlo Baby does not charge itself. I tried all possible solution. I need technical support but I live in Turkey. What can I do?
Are you using the supplied adapter ??
A normal usb adapter will not charge it.
see accessories ; https://www.arlo.com/en-us/products/default.aspx
Yes I Use supplied charger but it doesnt charge. I think there is a problem with usb socket of camera. Because it charges sometimes but just a few second
Hi @fkdrl116,
If your USB port is having a problem on your Arlo Baby, it would be best to have our support team look into this. I'll send you a private message to gather information from you to create a case for you.
Arlo Baby
