Arlo Baby Air Quality Readings Impacted by Heater?
Hello, I'm wondering if having the heat on in the house will impact the Arlo Baby's Air Quality Readings. I just plugged in my Arlo Baby 3 days ago and have noticed that while I'm at work (and don't have the heat turned on) the Air Quality readings are good (at zero), but during the night while I'm sleeping, we have the heat turn on when the temp dips below 71 degrees F, and I see that the Air Quality readings spike up a bit with each temperature spike (which I assume is when the heat turns on). Wondering if anyone else has seen this correlation and why it does this? Thanks! (see attached Air Quality and Temp charts from the last 3 days).
Hi @Kyle2020
Have you tried contacting customer support regarding this inquiry with your baby camera? I have attached the link here for you - Arlo Tech Support
Arlo Baby
