Hello,
This issue should now be resolved. Please make sure to have the latest version of the Arlo mobile app v3.2.1 If you do not see the update, remove and re-install the Arlo mobile app for the update.
Thank you
Hi @HFG
May I ask which version of the Arlo Mobile App you are using as well as which version of iOS your iPhone is using?
I just found the iPhone Arlo settings for turning on notifications on the locked screen but it doesn’t seem to have changed anything.
Grateful for any help you can give.
Hi @BabyM
I was not able to replicate this issue with an iPhone 11 Pro Max running iOS 14.1. Is it possible to provide a screen recording of the missing Lock screen controls after you go to the lock screen?
The file trim.e52a6349-3f0f-461a-8d15-f0cb392da1b1.mov does not have a valid extension for an attachment and has been removed. jpg,gif,png,pdf are the valid extensions.) I have posted it here: https://www.dropbox.com/s/it80m511qn4ym41/Arlo%20Baby%20screen%20recording.mp4?dl=0
I go to the Lock Screen by pressing the power button on the side and all audio stops! No Lock Screen Always Listening is displayed.
Hi @rebe1one
Does this feature eventually work or is it 100% not functioning on your iPhone lockscreen? Have you tried to remove & re-install the Arlo app by chance?
I'm also having a very similar issue. I can start Always listening and lock the screen on my iPhone 11 Pro Max running iOS 14.4.2 and version 3.1 of the Arlo app but after about two minutes it stops.
I have uninstalled and reinstalled the Arlo app.
HI @bp328i
Does this occur 100% off the time? Can you try and reboot your router and test again. Just to clarify, you have the latest version of firmware installed on the Baby cam version: 1.9.15.0_817?
Yes, 100% of the time and on all my devices, iPhone 11 Pro Max, iPhone 12 Mini, 11" iPad Pro, and iPad Mini 5 all on the latest iOS version.
I actually moved my router and Arlo Baby to a different room this morning and have the same results, between 1:45 to 2:15 it just stops. When I open the device I'm using and bring the Arlo app up it's always reconnecting.
Yes, firmware 1.9.15.0_817
Thank you for providing your feedback. The Arlo development team is currently investigating this issue. We will provide an update as soon as we have more information to share with the community.
I too am having the issue of Always listening shutting off after a minute or two, while its on in the background. Even if I'm just in my homescreen, after a few minutes, Arlo noise will just stop. When I go back into the app it will say Connecting... and reconnect quickly.
iPhone Xs Max 14.4.2
Arlo App 3.1
Arlo Baby Firmare 1.9.15.0_817 Hardware 6.
Just upgraded to Arlo App 3.2 and still cuts off after 2 min of background Always Listening.
Any updates on when this is going to be fixed? I've updated to 3.2 and have the same issue. The main reason I bought the Arlo Baby was Always listening.
Hello,
Can you try initiating the Always Listening feature, then start a live stream by pressing the Play button > put app in the background as normal and test again.
Thank you
Still stops after about 2 minutes.
Anything else we can try to get this working again?
Hello,
Thank you
Arlo Baby
