Doorbell notification Won't go away
- Email to a Friend
I get notifications and they wont go away. I click on the notifications and it does nothing. Pressing clear wont remobe it either. Happens on door bell and call from door bell
- Email to a Friend
I find they automatically go away after 10-15 minutes (haven't actually timed it).
- Email to a Friend
I am using Andriod phone with Android Pie OS. I have the exactly same issue which is really annoying. I had to turn off and or notification for Arlo to make it goes away. However, it suddenly comes again sometime later... Arlo, please fix this issue ASAP
- Email to a Friend
You can swipe right on this notification, tap the gear icon and minimize the notification. This will clear it from the pull down drawer.
- Email to a Friend
Hi JamesC,
Thanks for your reply. Actually, it doesn't go away by swiping right. If I minimize it, it comes back later soon. Restarting the device or accepting another doorbell call can get rid of it. That's really annoying me.
- Email to a Friend
I'm having the same issue. You can't swipe it away, disabling notifications will clear it teporarily, but it will come back and stay for good after. In addition I get duplicate notifications for EVERYTHING..... image is attached
I'm Using:
Android 8.0.0
Kernel 4.8.78-15104940
Build R16NW.G955USQU5CSA4
Arlo App Ver: 2.7.1_23406
- Email to a Friend
Hi @Ruffiano
Have you tried to remove & reinstall the Arlo Mobile App and test again.
You can also clear the app cache and test again. You can do this by going to Settings > Storage (device care) > Storage > Apps > Arlo > Storage > Clear Cache
- Email to a Friend
I'll give that a try. I was relunctant to do so as I've heard that reinstalling the app was the cause of the multiple notifications, and each time you do it, you'll just add to the number of notifications. We'll see if that is the case.
- Email to a Friend
You may also try contacting customer support regarding this issue before doing so? I have attached the link here for you - Arlo Tech Support
- Email to a Friend
I'll contacat support, as I thought, I am not getting 3 notifications for the same event.......
- Email to a Friend
