This issue should be resolved with the latest firmware release for the Arlo Audio Doorbell.
Please take a look at the release notes here and let us know if you still experience this issue.
Arlo Audio Doorbell - 1.2.0.0_309_283 – 8th August 2019
Try setting the switch to position 3. If it still buzzes, you might need to upgrade your transformer.
Brian
Agreed,
I have a Skybell video doorbell that I really like at my front door. My back door does not have any wires for a doorbell, so I am in a dilemma. The Skybell will work with certain chimes but I would prefer to go with Arlo. Unfortunately, the Arlo is not a video doorbell. Keep us informed as to how it works as I have a ton of questions.
Brian
Not sure they can fix this with firmware. This happens frequently on Skybell and Ring doorbells when the transformers are underpowered.
Brian
You wouldn't have gotten electrocuted. It wouldn't have ended well for your existing chime though.
Had this happen when I first hooked mine up. In my case it was because the wire on one side was stripped back way too far on the wires to the manual doorbell. The lighting wasn't that great so I didin't notice as the wire color was similar to the insulation color due to oxidation. After I hooked up the wires I went to the breaker box turned the breaker back on and as I passed the hallway where the chime was I heard this strange humming noise as you describe. I ran back and turned off the breaker and when I opened it back up that is when I noticed what had happened.
So basically the wires were shorted.
Glad that you found the issue and that the system is working properly.
I have the same problem it just keeps my current door bell buzzing, the arlo door bell is making a constant connection electrical somewhere in the doorbell.
You've checked the position of the slide switch inside the doorbell?
I moved the slider in all 3 positions and same buzzing
all 3 positions keep it buzzing , a constant electrical connection
Looks like you've hit the "trifecta". Some users reported that the buzzing was eliminated with one of the firmware updates. Please check to see what firmware you are running on the base station and doorbell and let us know.
Rich
My Arlo doorbell is hard wired now to my existing low voltage door bell. With the switch in position 1 or 3 my existing door chime buzzes and remains activated.
in position 2 it just doesn’t activate the doorbell at all. My house is 15 years old. The Arlo updated the firmware on installation of the doorbell. So is there no solution short of buying the Arlo chime?
There is nothing unique or unusual about my existing chime. I can’t seem find a proper solution here without buying more Arlo products. I believe this is a defect so I guess back it goes.
Rich
You can try getting another unit. I'm not sure that it will solve the problem. Various users have reported positive experiences with hardwiring while others have not. This is a headscratcher.
I am not sure which digital chimes work with Arlo and which ones don't. A mechanical doorbell chime that uses a transformer and a doorbell switch should work with no problems. Have you purchased the Arlo Chime and tried to use the doorbell just on battery power?
Brian
One would think that acutating a mechanical doorbell would be a simple task, but obviously not. The digital chime is probably the best route. That DOES work almost 100% of the time once properly installed.
The reason I mentioned that was that when I installed my Skybell video doorbell, there were all kinds of instructions, especially on transformers. Hooking up to a mechanical chime can be as simple as reconnecting the wires to the new doorbell to quite a frustrating experience if the voltages/amperages are not right.
Brian
Here are some excerpts from the Skybell troubleshooting page that might be helpful, I replaced the word "Skybell" with the word "doorbell":
It is not the doorbell making the buzzing sound; what you hear is the transformer installed in your home.
If your transformer is buzzing it means that your transformer isn't able to produce enough power for the doorbell.
The transformer must be providing 16v or greater in order to power the doorbell.
If you have a mechanical (ding-dong) chime occasionally, some of the older door chimes do not regulate the power/ current to the doorbell properly, which could cause a buzzing or humming noise. If you replace the door chime this issue will be resolved.
Brian
Interesting troubleshooting info. One really has to wonder how hard it would be to have an "electronic" doorbell that has a separate set of internal contacts solely dedicated to activated ANY chime? Yes, there are other things involved in the activation process, but the activation of an existing chime should ideally be relatively simple.
My Bell doesn’t work with my existing Chime also.
How difficult can it be to incorporate a simple switch to activate the chime when the button is pressed?
Looks like Arlo wants you to buy their chime for it to work, pretty pathetic.
