Doorbell not connecting to camera no sound or video just gray box spinning then disconnects after 10 seconds
Started happening after app update on 20th dec 2020
Disconnected all cameras doorbell and chime reconnected
Still no video or sound
Deleted app on iOS 13.3 iPhone 11pro added back still nothing
Has to be an app issue
And not even able to speak to anyone through mic and speaker
Tested on 4g and on home network WiFi
Doorbell makes chime work and notifies me someone has pressed but grey box with spinning icon for about 7-10 seconds then app shuts down
Hav you tried to remove the camera from Settings > My Devices > Re-Add it & test again?
Do you happen to have a screenshot of the error?
No sound or mic either when camera not paired doorbell rings phone and activstes chime
think it’s Had it how to I get a teplacement
I would suggest contacting customer support regarding this, I will attach the link here for you. Arlo Tech Support
Hi @RChobby
Does this occur on Mobile Data as well as your wifi? Does this occur on every doorbell press?
Seemed to start on 20th dec app update and still same on 2nd jan update
