Arlo Doorbell - existing wireless chime
  • 3283 Views
Marc76
Hi,
I've purchased the Arlo Doorbell and had itt imported from the US to UK. I now see that when I read that it was compatible with existing chimes, it only meant wired.
Is it possible to connect the Arlo doorbell to an existing wireless chime?
Not to my knowledge...
Arlo chime or pre-existing wired dooebell
jody669
I’ve imported one too.
It needs a wired doorbell.
Cheap enough from amazon. You can link it to a cheap doorbell that runs off a 9v battery
Seems pretty good apart from
I’m trying to link it to my amazon echo dot and I can’t make it chime through it.
Marc76
I'll check out the 9v door chimes on Amazon, thanks for the tip.
It doesn't look like it's going to be possible yet to link it to the Samsung Smartthings hub. Hopefully there will be more support for home automation hubs soon
  • 3284 Views
