Arlo Audio Doorbell can't sync with Base Station. Shows weak signal. How to make signal stronger?
Hello I have an arlo doorbell. The problem is that it is difficult to synchronize with my base station. They are at a distance of about 15m, on my Arlo application the doorbell signal is weak! What solutions to make the end stronger? thank you in advance
This can be due to house construction, especially stucco. Also, metal objects in the direct path between the base and doorbell can block the signal. Try bringing the doorbell close to the base to sync it. Move it back to the door and see if it works properly.
