What is the difference between ARLO VMC2030A VS VMC4050P vs VMC3050
I have ARLO VMC2030A - after three years the battery life is pretty much useless, I'm needing to recharge it every 2-3 weeks, which is tricky as I'm short!
I'm looking to purchase a new one and I think they have changed in the past three years.
What is the difference between ARLO VMC2030A VS VMC4050P vs VMC3050?
They range in price from $130 - $160 and look pretty much the same.
I'm happy to purchase the cheapest one as the one i had did it's job - so I'm confused by these options.
Thanks in advance for any help.
VMC2030 is of course what you have now.
VMC4050 is the Pro 4. It is a 2K camera that has a removable/replaceable battery (unlike the Essentials)
The VMC3050 is the Essential Gen 2. It is a 2K camera like the Pro 4. It also has a fully sealed battery (not user replaceable) like your first gen Essential.
