VMB5000 AC Adapter Replacement
I need a replacement AC adapter for my VMB5000. The P/N is 332-50096-02 and model is 2AAJ018F1.
Input: 110-120v/50-60 HZ
Output: 12v/1.5 amps
I haven’t been able to find a replacement on the Arlo site. I’ve seen a number of adapters on Amazon, but I would like to know if anyone has a suitable recommendation for replacement? Thanks
Hello, I am searching for the same AC adaptor. Did you find one from Arlo or a 3rd party site? Thank you
There are universal power supplies available that should work fine. You'd need to verify the voltage setting and the size and polarity of the connector compared to the original.
A router power supply may also work but check the same issues as above.
It's a pretty common 12 volt adapter. I suspect anything on amazon that claims to be compatible will work.
