- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- App Add device > Arlo Video Doorbell 2K (2nd Gener...
App Add device > Arlo Video Doorbell 2K (2nd Generation) has no smart hub VMB4000r3 option
I've read that the new Arlo Video Doorbell 2K (2nd Generation) is compatible with the Smart hub VMB4000r3.
When I add the Arlo Video Doorbell 2K (2nd Generation) device through the app, I'm never given the option to select the smart hub. It only allows me to connect to the network.
I've done all firmware updates, removed devices and tried to add again but no luck.
Smart hub firmware: 1.21.1.0_4302_9611cf3
Hardware: VMB4000r3
Hook up type: wired
Arlo Video Doorbell 2K firmware: 1.4.2_720_d572335
Hardware: AVD4001Aer1.3
Where did you read that? None of the Gen 2 cameras can be paired to a hub. Arlo has said they will add the feature, but they haven't said when.
Right! You are 100% correct. This post is referring to the "Arlo Essential Wired Video Doorbell".
So users are required to purchase the subscription plan? That's lame!
I think I'm going to return the Gen 2 and get the older one so I can use it on the smart hub.
2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
communication
deta
Doorbell
drained battery
Feedback
intermittent
Mechanical chime
no app model
noise
Phonecall
Secure Plus plan
Secure Trial Active
speaker
Talk
wired
Wmb4540
