How do you connect to ac power?
How do you connect to ac power, everything was working ok, but now got a message stating connect to ac power ???
Depending on what you're trying to do, generally you would use an outdoor power cable.
Likely you are getting this message because your subscription expired. If you don't want a subscription, then you can either remove your activity zones, - or (as @jguerdat suggests) connect the camera to an outdoor charger.
Many thanks, that sounds like the reason 👍
Arlo Pro 3 Floodlight
