How bad is notification/recording delay?
Considering buying the wireless Arlo Essential (2nd gen) for starters. I’m seeing a lot of complaints that there’s so much delay that Arlo products are basically useless.
How bad is the delay for recordings, notifications, and live video? Regarding live video, is it a delay starting the feed, or is it a constant delay where video is always significantly behind, or both?
Also open to any other opinions that could guide my decision to purchase, thanks.
Lag (delay) in accessing the cameras or starting recording are typically due to poor signal strength and/or quality of the WiFi signal.
There will always be a short delay due to the cloud-based implementation. Something triggers the need to activate the camera, it connects to the servers and then the requested activity can occur. This lag is generally 2 seconds +/-. If it's significantly longer, troubleshooting is needed to improve the connection.
Use of an appropriate AC adapter provides a 3 second look-back which helps with recordings but not with live viewing.
180 degree
Android App
animal
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Essential Camera feature request
Essential outdoor
Google Nest
Idk
need help
New features
Night vision
Payment
privacy zones essential 2k
Record
smart things
Unknown charges
