Can you trigger more than one camera with Arlo Audio Doorbell?
Hi , does anyone who has one please tell me if you can trigger more than 1 camera ? Also can you select the trigger? Eg the doorbell button over the motion sensor or is the only trigger the motion sensor. I am wanting to enable a button press to trigger 3 cameras at the same time. Many thanks to anyone who can answer this for me
There is no button to make multi cameras record....
BUT, you can cross trigger ( it used to work perfectly but lately has been abit wonky as to all recording )
You create a CUSTOM mode.
Add camera A to sense and A to record....save
Go back and edit the new mode to add a second ( or additional ) camera
Add camera A sense and B record save
etc as needed
Exp with 2... it can be re sense / record
A A
A B
B B
B A
In the case of the doorbell, it is the doorbell that would cross-trigger the camera(s). This can only be triggered by the doorbell's motion detector, not pressing the doorbell. So you'd end up with more recordings than you might want.
