Can't install chime 2
  • 14 Replies
  • 2493 Views
Carrama
Hello everyone,
Have used arlo for years have all cameras and wireless video doorbell, but..6 months ago i brought chime2 AC2001.. i have had IT Gurus look at it and try to fix it and read everything on here and tried everything 100 times ,yes re setting etc etc etc etc etc... but will not work... it automatically tries to connect to arlo base wifi thru your phone.. you change to other main house wifi... but no go... it is such expense frustrating peice of rubbish..i have spent more time and money than i paid for it in the first place.... the normal chime looks easy... ... how can i get money back as 6 months ago i brought...but still cant use.. please help thanks...
14 REPLIES 14
Carrama
Looks like plenty people have the same problem...
The Chime 2 doesn't connect to your base or hub - it uses your home WiFi.
Do you allow the phone to connect to the temporary WiFi created by the chime? You can't pass your WiFi's SSID and password to the chime without doing so.
https://kb.arlo.com/000062551/What-do-I-do-when-Arlo-fails-to-discover-my-Arlo-Chime-2-when-I-set-it...
ShayneS
@Carrama Were you able to verify what jguerdat mentioned?
Carrama
It asked for password or says incorrect password
Where do you get that from
Carrama
 says connected...but light still flashes and no go.... so complicated ... buy a set of wifi anything and in 2 minutes you off and away... this is designed and never tested for customer use or satisfaction and obviously only in a laboratory
Carrama
Which network is temporary.... the arlo 0124 or the VMB one?? The Arlo 0124 one does connect but nothing happens... the vmb one requires a password... so have no idea
The VMB one is for your base or hub so it would appear that the "0124" one is correct. It will only show up when installing and at no other point.
Carrama
So....
What next... you see screen shots above it can connect eventually to that 0124 ....BUT... the white light fades in and out... and nothing more
So what now...
Carrama
I am at home now could you ring or help sort while you there responding please
This is a user-to-user forum, not Arlo support.
To your main question - there was a post from someone else a few days ago who also had this problem.  He found that he needed to disable face id temporarily to get it to work.  So try that next.
Carrama
Not sure what you mean.
I have an Android phone and dont use any such... stuff
Also please give number for support..becuase impossible to find...
Again, this is a user-to-user forum.  I don't work for Arlo.
They don't publish a number.  You need to access support through the app.  I understand that's a big problem if you don't have a camera in a subscription plan.  I'm tagging the two Arlo mods ( @JamesC and @ShayneS ) to see if they can help.
Carrama
Ok thanks...
I can never work out how to get onto any support..and last time the person was so thick they just kept sending me what you can already.. download...
I have a subscription plan i have 4 camera.s plus video doorbell...
It is so disappointing... anyway...arlo will slowly take them selves out of the market service and backup =growth and longevity.
But my son went with another brand And so easy and cheaper..
Unless JamesC and ShayneS... have some ideas...arlo fans...look out for some cheap cameras etc...
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
  • 14 Replies
  • 2494 Views
